HP increase with Injectors only?
Old Jul 20, 2005 | 02:42 PM
nightrider46's Avatar
Default HP increase with Injectors only?
I have stock 240cc injectors in my b16 and i did alil homework on the injector on a 94-98 eclipse. The eclipse injectors could fit the b16 engine but increasing the CC's of the injectors, would it make more HP by just switching them? or would a regulator and fuel rail would be needed ?
Old Jul 20, 2005 | 03:02 PM
Pete's Avatar
Default RE: HP increase with Injectors only?
you might get a little.........but i doubt ud notice it. FASTCIVIC did something like that BUT he did bigger injectors......fuel rail......adjustable fuel pressure regulator, and an ECU piggyback (i think he has the venom)......im not sure if he changed the fuel pump for a 255lph......but it would def help. LOL ANYway im goin to have to say u wont get much hp outta the injectors unless u beef up the rest of the fuel system as well.
Old Jul 20, 2005 | 03:03 PM
fast93civic's Avatar
How much bigger are the eclipse injectors that the stock ones on your b16? Usually when you replace injectors you get a fuel pressure regulator and a fuel rail. But, just replacing the injectors could make your car run rich. Remember more gas doesn't equal more power, what could happen is that you could actually lose power. You have to have the air and fuel ratios balanced. This could require a VAFC. Saciocons will have the full awnser to your question.
Old Jul 20, 2005 | 03:20 PM
so should i get a fuel regulator and fuel rail to push more fuel to the stock injectors instead of getting the eclipse injectors ?
Old Jul 20, 2005 | 04:29 PM
Just curious, what mods do you have currently done to the motor?
Old Jul 20, 2005 | 04:34 PM
US3R!!!11one's Avatar
Yes please give a mod list. If your car is stock, this mod will do nothing except hurt the car.
Old Jul 20, 2005 | 05:08 PM
i have a 97 civic DX with a B16 swap, i have 4-1 headers, short ram intake, msd external coil, msd spark plugs, 2 1/2 inch straight pipe with high flow cat, ACT Stage 2 cluch kit i think thats about it
Old Jul 20, 2005 | 05:11 PM
thats all for engine. i have more mods but it's exterior and interior
Old Jul 20, 2005 | 06:04 PM
polo708's Avatar
You can make it pump more fuel, but without forced induction/nitrous you wont really get it to pump more air. Like said above... all you will be doing is making it run rich (which is good for detonation control) but after a certain point running rich actually hurts you. If you add fuel you must add air...
Old Jul 20, 2005 | 10:17 PM
exactly... If you want to put more fuel in the motor figure out a way to get more air in it as well. A way to start would be getting a larger TB and an aftermarket intake manifold, and or a turbo or a supercharger.
