I need an educated opinon on hp
i have a 92' Civic DX with a high compression ZC/d15 ...
i have a AEM cold air intake, OBX Intake Manifold, new headers/ downpipe, a Hi Flow Catalytic Converter, dual exhaust, 10mm sparkwires etc.. and tons of suspension work. im tryin to get an estimate of my HP. i figure its around 150-166. any ideas? any questions, let me know |
no way
more like 130 |
Originally Posted by steeledrummer32908
(Post 639223)
i have a AEM cold air intake, OBX Intake Manifold, new headers/ downpipe, a Hi Flow Catalytic Converter, dual exhaust, 10mm sparkwires etc.. and tons of suspension work. im tryin to get an estimate of my HP. i figure its around 150-166. any ideas? any questions, let me know 1st time https://www.hondacivicforum.com/foru...ad.php?t=74830 i have a 92' Civic DX with a ZC/d15 i have a AEM cold air intake, OBX Intake Manifold, new headers/ downpipe, a Hi Flow Catalytic Converter, dual exhaust, 10mm sparkwires etc.. and tons of suspension work. im tryin to get an estimate of my HP. i figure its around 150-166. any ideas? https://www.hondacivicforum.com/foru...ad.php?t=74606 i have a 92' Civic DX with a ZC/d15 i have a AEM cold air intake, OBX Intake Manifold, new headers/ downpipe, a Hi Flow Catalytic Converter, dual exhaust, 10mm sparkwires etc.. and tons of suspension work. im tryin to get an estimate of my HP. i figure its around 150-166. any ideas? 3hp for the cai 5hp for the header 2hp for the cat 5hp for the exhaust (these are all +/- but still close) what d15 motor do you have? Btw this is the 2nd time you've thread jacked. Create your own thread or do a search. |
if that's the stock engine I would say 105WHP MAX
first of all..wow
you need to take a chill pill. i would apologize to you for not getting answer, but i wont. because there is an infinite amount of space out there, and the fact that you got your feelings hurt that i took up a couple inches more then was needed due to lack of forum experience..lol give a noob a break okay n.e way... i did a little research and the specs for my engine is like 106 hp at stock. and the parts that i bought advertise certain performance increases and thats what i was adding. i understand that they prob high ball them amounts but give me a sec and i'll get them |
(Post 639240)
first of all..wow
you need to take a chill pill. i would apologize to you for not getting answer, but i wont. because there is an infinite amount of space out there, and the fact that you got your feelings hurt that i took up a couple inches more then was needed due to lack of forum experience..lol give a noob a break okay n.e way... i did a little research and the specs for my engine is like 106 hp at stock. and the parts that i bought advertise certain performance increases and thats what i was adding. i understand that they prob high ball them amounts but give me a sec and i'll get them What brands are all the parts you mentioned? It helps to know, as some headers are better than others, for example. |
heres a few
D-Series Stainless Steel Racing Performance Header!! 4-2-1 Stainless Steel Racing Header Brand New and ready to ship High quality T304 Stainless Steel material piping with CNC Machine Made Flanges Directly fits on the Stock Honda Civic D-series Sohc Engine Light weight Design. Increases ~ 10-15 HP __________________________________________________ _________________ Increase Air Flow and Performance 100% High Quality Stainless Steel with Polish Finish Surface Increase 5-10 Horse Power Straight Thru, Direct Bolt-on Design Easy to Install This Test Pipe / Resonator is for Race and Performance, Off Road only. __________________________________________________ _____________________ OBX High Power Air Intake Manifold Systems Made from T-6061 lightweight billet aluminum and chrome plated Increased volumetric efficiency by 70% over stock intake manifold 10-15 horsepower increase Utilizes factory sensor positions and auxiliaries Accepts up to 66 mm throttle body Lifetime warranty from manufacturer defects |
Okay, a few things. eBay generic headers suck and you might get 1hp from it.
That's not a high flow catalytic converter, it's a test pipe. A catalytic converter has a catalyst in it, and what you have doesn't. You probably gained 4hp from the test pipe, but it's illegal, smells horrible, pollutes more, and makes the exhaust raspy. You need to get a real high flow cat. You will only lose 1hp by switching from test pipe to high flow catalytic converter. OBX Intake manifold might gain you 5hp, but probably less since OBX doesn't make very good parts. Question: why do you buy the cheapest parts possible? If you're not gonna do it right, you might as well not do it at all. Higher quality parts give you better gains and have better construction/fitment. |
lol, i went cheap cause im 21, married and have a 1 year old and wife is prego again. not alot of extra cash lol
(Post 639247)
