IDLE
idle spot should be 1k to 1500 correct me if I'm wrong. But yeah I also have that problem my car idles around 500 to 600 and feels like its going to die or something. Still can't figure out what's wrong.
it depends on model of car and transmission, on my 95 ex with a manual, the book says sumthing like 650, and 850 or something for the auto. i have mine set a lil higher like 800 - 900 caue ive got bad compression in one cylender and bad motormounts so the higher rpms keep the shakes down
ORIGINAL: danomatic93
If you have stock RPM gauge there is a line right above zero. That's the warmed up idle rpm spot.
There is a procedure that you need to follow when re-setting idle, it's also found in the manual. Follow the correct procedure or else you're just turning screws..
honvic
Sep 2, 2011 09:49 PM
JBaris
Nov 22, 2010 03:56 PM
tsh30039
Sep 30, 2006 02:45 AM
green1996civic
Jun 14, 2004 06:26 PM
