HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   Idle out of control (https://www.hondacivicforum.com/forum/engine-internal-11/idle-out-control-93669/)
MrGonzo123 Jul 10, 2012 05:13 PM
Idle out of control
Someone PLEASE HELP!!! When I start my Civic.. It revs high for like 5 seconds then revs up and down.. WTF What do I do to fix this !!:mad::mad::mad::mad::mad::mad::mad:
cvcrcr99 Jul 10, 2012 05:55 PM
Does the issue go away once the car is warmed up?
First thing to do would be to remove the IAC and clean it out since that controls the idle.
inthezoneac Jul 13, 2012 05:26 PM
^^^ clean idle air control valve
also try this after your car has been sitting overnight so it's cool. Turn your car on, spray some brake cleaner around every vacuum line, seal you can find. If your engine hesitates at any point go back to that spot, spray some more and check.
replace any bad lines/gaskets.
MrGonzo123 Jul 14, 2012 12:06 PM
Idle gone wild
So i replaced the IACV.. No more Idle revving up and down.. thanks for the Advice guys !
cvcrcr99 Jul 15, 2012 10:06 AM
Sick! Glad to hear this was resolved.
