installing a block heater on my 98 DX???
My 3" thick honda service manual doesn't seem to have anything about this. Anyone done this? Where does it go? Any pics or instuctions? I'm looking at getting this one: http://www.napaonline.com/masterpage...eeze+Plug+Type
Thanks. |
RE: installing a block heater on my 98 DX???
maybe it's not for honda??? that's the first time i've seen that. what is it?? what does it do?
those are for deisel engines. the way deisel engines work is by compressing the air before introducing the feul, then injecting the feul at TDC. since physics tell us that when something compresses it heats up, the air is hot and ignites the feul when it enters the engine. this allows for much higher CR's and better feul economy. however, in the winter the intake air is cold enough that even compressed its not hot enough to ingnite the feul, so some genius came up with these 'block heaters' that heat up the air inside the cylinders.
at least im pretty sure thats what that is. its kinda vauge. |
Yeah man, block heaters are for diesels. You don't need it, we these fancy things called, now this is important, "spark plugs". Diesels don't. Thats why they need block heaters. On cold days/nights, they can't get the fuel to ignite from compression alon, we have that nice little spark to start our babies. Leave the block heater for somone else to buy.
Hari - that is the part napa indicates as fitting my civic. They heat the coolant in the block (see below).
Nail- Block heaters are not just for diesels.. the genius that came up with this exact type of block heater (see link) for gas engines did so to heat the coolant in the block for faster warmups (includes warm heat within a couble mins) in cold winter conditions. The oems block heaters (both freeze plug types) on my Ranger and F150 (both are non-diesel engines) worked so nice this past winter here in Alaska, I have made the determination that I will be putting one in my civic. Here's some info on installing the genuine honda part on a '02: http://www.hondaautomotiveparts.com/...hidmodel=Civic and where you see "HEATER, ENGINE BLOCK" click on the Installation Instructions to download the PDF. Since my original question was install on my older civic (assume its different than the '02 model instructions above)..........anyone else? |
****, I drive a 98 DX coupe also and might like a block heater also. Let us know if you find anything out.
My car takes like 4 minutes to get the heat goin in january.
Pete, but than again we're not in teh Far North:-D
mine took like five in december for me...and im in west michigan....and lake-effect snow is a bitch.
ORIGINAL: Kedawei ****, I drive a 98 DX coupe also and might like a block heater also. Let us know if you find anything out. |
