insulating fuel line
So I read somewhere that if you insulate your fuel lines you will get slightly better performance because it will keep them from getting hot. I also figured the same concept would apply to my short ram because it does heat up significantly.
has anyone ever tried this and noticed any results? would this heat resistant tape do the job or should I use something different. http://cgi.ebay.com/Mylar-Heat-Resis...item4ceb7ce9fc |
i dont think it would a significate increase or enough worth spending time and money on.
:P cant say I would like seeing my intake tube covered in blue tape either.
if anything buy a plastic intake tube, its less of a conductor of heat.
