integra head swap
Old Sep 20, 2006 | 07:51 PM
yoRt's Avatar
Default integra head swap
ok im new to hondas and dont know what kind of engine i have but its a 1998 5 speed, 1.6 litre bottom of the line car, no power i cant even tell if its an ex, cx, hx, or whatever but theres a 1990-1993 body style integra with the stock dohc engine in it at a local junk yard and i was wondering if you can do a direct head swap from that car to mine so mine would go from a sohc to dohc.......any help would be appreciated and if it is possible how much would a head cost or run me? thanks
Old Sep 20, 2006 | 08:07 PM
HARI.'s Avatar
Default RE: integra head swap
you can't just do a head swap to get a dohc motor. you need to change the whole thing. right now you have a d-series motor and the 90-93 integra motor is a b-series.
Old Sep 20, 2006 | 08:37 PM
Remmy's Avatar
A dohc head will not swap to a sohc head.
Old Sep 21, 2006 | 09:37 AM
yoRt's Avatar
ok so i would have to take the whole engine? would i need almost everthing and would it be a worthy swap or no? what type of engine is used on integras stock for that year?
Old Sep 21, 2006 | 04:09 PM
sillyredcivic's Avatar
If you live in an emission controlled state that will not be a street legal swap. When you go for emissions you will fail because that motor is older than your car. If your going to do a swap find a swap out of the same year or newer vehicle and make sure you get all the parts you need, engine, tranny,, ecu, wiring harness, shift linkage, etc.
sergiog
Apr 14, 2011 05:23 AM
kvh
Feb 22, 2008 10:15 AM
rec4x4
Feb 14, 2008 08:22 PM
domex
Feb 12, 2007 10:24 PM
mycivic
Nov 22, 2005 11:38 PM
