Integra LS-Vtec
ORIGINAL: Marty
I mean it is nearing its abilities without a big spendy build.
For the LS/VTEC you need.
LS (B18A/B) or CRV (B20A/B/Z) engine (the B20 has a knock sensor the B18 does not)
B16 head
LS/VTEC kit (dowl pins, vtec oil line, gasket)
A VTEC oil line must be ran to the head inorder for VTEC to work. The b16 head has to have some holes opened up to fit dowl pins so the head will sit on the block. And you can install the knock sensor also.
LS/VTEC n/a engines with high comp pistons and bolt ons make well into 230hp range.
B16 head
ORIGINAL: Lost
B16 head
B16 head
you can go on ebay and they sell motor packages where you can get the entire swap with motor, intake, ecu, etc and brand new mount and new axles for like 3200, that where i got mine at
ORIGINAL: basbal123
[&o] if i could only get my si to work properly i wouldnt have to sell it[&o]
kvh
Feb 22, 2008 10:15 AM
domex
Feb 12, 2007 10:24 PM
JDMB16CIVIC
Aug 11, 2004 07:29 PM
JDMB16CIVIC
