Internals suggestion
Old Apr 11, 2008 | 06:34 AM
Default Internals suggestion
Hey everyone. I own a 99 EX y8. After scrapping many ideas, I have decided to keep the stock d16 in the car (mainly due to cost).
I have, but not installed, Crower stage 2 camshaft, Supertech valve springs and titanium retainers, Skunk2 cam gear, Cometic head gasket, ARP head bolts and studs. However, I have installed a CAI, and DC header.
Eventually, I will install an air intake mani, slightly bigger throttle body, bigger injectors, fuel rail and pressure regulator. When the money is available.
I guess my question is, is there anything else you would suggest (internally) that I could install while I have the head taken apart? Spoke with my friend, he said upgrading valves requires machine work etc. Any suggestions would be appreciated! Thanks
Old Apr 11, 2008 | 07:12 AM
riceburner700's Avatar
Default RE: Internals suggestion
it wouldnt be a bad idea to have a 3 angle valve job performed on the valve seat if you put brand new valves in there. A decent port and polish you can do while the head is off
Old Apr 11, 2008 | 04:30 PM
If iwas to port and polish, wouldn't that require a bigger HG? Right now, theone I have sitting in the Cometic package is75.5mm. I dont think I will be installing new valves due to the required machine work. Thanks for the reply riceburner.
Old Apr 11, 2008 | 08:51 PM
jamned's Avatar
You won't need a bigger head gasket for a P&P.
Old Apr 12, 2008 | 08:45 AM
bcivic's Avatar
maybe higher compression pistons not to high but higher would help power and torque and a tune
skipdman
Aug 30, 2005 12:11 AM
ballplaya4eva07
14
Mar 7, 2005 09:06 AM
AgentofDarkness
Jan 23, 2005 09:31 PM
ballplaya4eva07
Dec 10, 2004 04:35 PM
AnakinKenobe
Sep 10, 2004 08:28 PM
