JDM d15b cam in mini me y7/y8???
So i've just done my mini me swap and am having some timing problems...
I have a jdm d15b cam in my d16y8 head which is milled .030 over, with a y7 block... Y8 adjustable cam gear... I read that for every .012 milled a retard of 1* is needed??? So since i milled it .030 over i would need to retard the timing 2.5*, correct??? Since the jdm d15b cam is almost the same as the d16z6 cam... and since i have it in the d16y8 head the "half a tooth" theory applies... http://www.d-series.org/forums/engin...-sprocket.html which means i will have to retard the timing 4.75* correct??? If so would i need to retard the timing to 7.25* for it to be correct, correct??? Any help would be greatly appreciated, thanks... |
