knocking noise
i have a 1999 honda civic ej and its running ok i guess. i have a problem though.. i will be cruising in 5th gear and if im under 3 rpms and try to punch it it makes a real bad knocking noise. so if you guyz know anything about this please message me back.
RE: knocking noise
Check all fluid levels first, but it sounds like a detonation problem. I would try running seafoam through with the gas. That will loosen up carbon buildup in the cylinder head/piston area. NAPA and autozone sell it....
RE: knocking noise
do a compression test to see if all your cynliders are healthy or not. knocking noise usually means a bad rod which could end up being a blown motor if not taken care of
RE: knocking noise
ok so i guess its a compression test it is then.. so what if the cylinders are good and healthy but still making that knocking noise. my friends said that it could be a rod too..
RE: knocking noise
ORIGINAL: c1v1cbo1817 ok so i guess its a compression test it is then.. so what if the cylinders are good and healthy but still making that knocking noise. my friends said that it could be a rod too.. |
RE: knocking noise
is it a knocking or more of a ticking.
RE: knocking noise
im thinking you guyz are right about the rod knockin... so i guess its time for a rebuild.. what do you guyz think??
