knocking noise
Old May 21, 2007 | 04:50 PM
c1v1cbo1817's Avatar
Default knocking noise
i have a 1999 honda civic ej and its running ok i guess. i have a problem though.. i will be cruising in 5th gear and if im under 3 rpms and try to punch it it makes a real bad knocking noise. so if you guyz know anything about this please message me back.
Old May 21, 2007 | 05:08 PM
scott's Avatar
Default RE: knocking noise
Check all fluid levels first, but it sounds like a detonation problem. I would try running seafoam through with the gas. That will loosen up carbon buildup in the cylinder head/piston area. NAPA and autozone sell it....
Old May 21, 2007 | 05:32 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
do a compression test to see if all your cynliders are healthy or not. knocking noise usually means a bad rod which could end up being a blown motor if not taken care of
Old May 21, 2007 | 09:11 PM
ok so i guess its a compression test it is then.. so what if the cylinders are good and healthy but still making that knocking noise. my friends said that it could be a rod too..
Old May 22, 2007 | 08:47 AM
ORIGINAL: c1v1cbo1817
any power loss? anything else that is going wrong with the car? a rod would knock like that as well.
Old May 22, 2007 | 09:12 AM
Marty's Avatar
is it a knocking or more of a ticking.
Old May 24, 2007 | 05:11 PM
im thinking you guyz are right about the rod knockin... so i guess its time for a rebuild.. what do you guyz think??
jarchuleta03
Jan 31, 2007 12:25 AM
nardva
Oct 8, 2005 12:58 PM
rupes33
May 11, 2005 05:13 PM
sflaboy25@yahoo.com
May 5, 2005 05:21 PM
Gvaski
Mar 11, 2005 09:14 PM
