HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   loud squeel (https://www.hondacivicforum.com/forum/engine-internal-11/loud-squeel-55397/)
FadedShadow01 11-09-2007 09:18 PM
loud squeel
when ever i take off i think my belt from my alternator to under drive pulley squeels really loudly an its amberessing. anyone had this done before. how do i fix this?
sleeper99ex 11-10-2007 10:08 AM
RE: loud squeel
do you still have ac on the car?
if it is the alternator then you should be able to tighten the belt. if that doesnt work then just repace it. they are pretty cheap at the parts store.
FadedShadow01 11-10-2007 09:43 PM
RE: loud squeel
the ac is no longer on the car. so i'm thinking about buying a knock off megan racing under drive pulley and replaceing the belt at the same time
mk378 11-10-2007 11:27 PM
RE: loud squeel
If it's a stock drive pulley you probably just need to tighten or replace the belt. If a pulley has been replaced, check that the pulleys are aligned quite closely in the same plane side to side or there will be noise. If necessary replace the pulley or shift the alternator.
