Lower Compression
would a thicker head gasket lower compression? and also, does anyone know of anywhere that will make a custom head gasket that thick?
RE: Lower Compression
cosmetic might be able to make custom gaskets in different thicknesses. Yes a thicker head gasket will lower your comp depending on how thick
Well heres the question for you, i can get 8.8:1 compression ratio pistons, and i was wondering if i should try and go lower, and obviously the thicker gasket would do, but how thick?
