lower compression
RE: lower compression
[:@] just drop the cash on getting low comp forged pistons in it. if you use the thick head gasket, you only get the detonation resistence of about half of the actual CR drop you get. so you kill your low end power to run a couple more psi of boost. just keep it stock and keep the boost low, build it right, or wait till you can.
jpcalhoun
01-28-2014 12:43 PM
