Ls build head ideas
Old Oct 22, 2007 | 07:27 AM
natecivic92's Avatar
Default Ls build head ideas
Alright here is my sitiuation, My ls b18b1 block is at the machine shop we are putting dalton 81mm flanged sleeves ,crower rods and ,wesico pistions it is the 9 flat top compression.I am running the ls head(rep for the non vtec peeps)My question is what all should I do to my head?New cams?valves?I am running the t04 flange turbo and on pump gas 4 pounds of boost.On race gas upwards of 18pounds or so.Mike at the machine shop says my valves need to stay open longer can someone help me on this subject and get headed in the right direction........ Thanks Nate
Old Oct 22, 2007 | 07:58 AM
riceburner700's Avatar
Default RE: Ls build head ideas
run turbo cams
Old Oct 22, 2007 | 08:06 AM
What would be a good company to go with on the turbo cams?
Old Oct 22, 2007 | 09:28 AM
hear a lot about gsr cams which are pretty cheap or you can get some turbo cams from crower. i would do a little more research first though on if the cams are compadable, i dont see why not though
94civichatchback
Dec 25, 2009 11:10 PM
turbo speeder
Jan 28, 2009 03:57 PM
scottyb2fast
Sep 24, 2008 04:54 PM
projektcivicturbz
May 2, 2007 07:48 PM
Cyrano
Jun 24, 2005 08:41 PM
