ls v-tec turbo it?
ls v-tec turbo it?
hey guys i got a ls v-tec coming on the way [sm=bounceybounce.gif] cant wait cant wait!! other than that i was wondering after the ls v-tec should i boost it cause i heard bad stories about the ls v-tec and its blowing up scenes. anyways thanks.
RE: ls v-tec turbo it?
well keep the boost down, and build it properly (sleeves, pistons, rods, valvetrain) and get a good engine management system (aem ems, hondata) and you should be fine. boostheads love the ls/vtec combo. you get the displacement of a b18, plus the higher revving capability of the vtec motors, and it is not too expensive. so run 16-18 psi non intercooled on stock internals [&:]
so wait im getting 2 opinions here but i kinda get where you guys are coming from if i just put the v=tec head on then i shouldn't boost the motor unless i do internal motor work like pistons etc. but if i dont do that then dont put v-tec cause of high compression.
ORIGINAL: jdmekb16
yea bro boost it 18 PSI......goood idea.......thats a TAD too much boost.
IMO. no. theres a lot of peopel out there that swear by it, but i just dont trust it. the C1 is just a much more well put together block. get the VTEC head and just slowly get parts for it. put type r valves, aftermarket springs and retainers, cams, maybe save up and get a P&P (dont do it yourself) then save up and get a C1 or even a C5 block, and throw it together and have a sweet NA motor.
