ls vtec
Old Mar 24, 2007 | 12:43 AM
Djohnsto's Avatar
Default ls vtec
Well I had a b18b given to me a while ago...but due to holidays and stuff I havent been able to put any money into it until now
So the questions I have are...
What is the best tranny for a ls vtec engine and what kinda compression pistons should I get since I do not plan on boosting? As much as i would love to turbo, i just cant afford to go through all that and lose alot of money if something goes wrong
This is going in a 92 eg just to let everyone know
Old Mar 24, 2007 | 11:05 AM
skylinecivic's Avatar
Banned
Default RE: ls vtec
well its all depends what u want 2 do on my civic im working on im using ls motor and la tranny but b16, b18gsr,or lsd trans typr r trans are most common but i have stock, header, fuel rail the common stuff but if u plan 2 boost change the oil pump to a typr r if u plan 2 boost u can used stock up 2 11psi with a gruard block 7 without it i done this and everything works out perfect 4 me
Old Mar 24, 2007 | 11:11 AM
drbyers's Avatar
Default RE: ls vtec
you don't need to swap out the pistons if you don't plan on boosting.
if you want higher compression, however, look into some type R pistons which have the domed heads that will bump up the compression a lot.
and if you do put in type r pistons, look into aftermarket valves, springs and retainers and aftermarket cams such as toda, skunk2 or blox.
but if you have an EG, an ls-vtec swap should be pretty decent as is.
Old Mar 24, 2007 | 02:53 PM
Djohnsto's Avatar
Default RE: ls vtec
yeah...i figured bumping up the compression would give me a few more ponys...and yes i plan on putting an aftermarket cam with springs and retainers
edit....what kind of compression ratio would type r pistons give me?
Old Mar 24, 2007 | 04:34 PM
easy101's Avatar
Default RE: ls vtec
a friend of mine put together a nice motor using an LS block. He used type r pistons, titanium exhaust valves, springs, retainers, he kept the ls head and had it decked, port & polished and he used a skunk 2 intake mani, throttle body, rc 440's, crane stage 4 cams, JDM header. His set up runs real nice. Good luck to you, you're gonna be spending some $$$ lol
Old Mar 24, 2007 | 06:47 PM
Djohnsto's Avatar
Default RE: ls vtec
I definately do not wanna go as aggressive as a stage 4 cam...this is my dd were talking about
The only mods I have in mind really are higher compression pistons, cam, valves, springs retainers, intake mani, tb, cai, and full exhaust.
For pistons and cams I might just stick with the oem type r or gsr...depending on prices.
Possibly get it tuned after all is done if I can find someone in my area.
But, I wanna know what kind of compression ratio I would be looking at with type r or gsr, or should want to get to.
Old Mar 24, 2007 | 11:51 PM
drbyers's Avatar
Default RE: ls vtec
type r pistons are severely domed. they bump up the compression beyond 11 psi if I remember correctly.
the pistons are expensive too, but i think there are some aftermarket alternatives.
the reason the type r pistons are so beloved is because they have side coatings that make them more durable to high rpm stress. but since you have a regular ls block you won't be hitting vtec highs.
Old Mar 25, 2007 | 10:56 AM
Djohnsto's Avatar
Default RE: ls vtec
so a good n/a compression ratio for a dd would be around 11:1
or should I want higher if I have the budget to get better pistons?
Old Mar 25, 2007 | 11:57 AM
Kedawei's Avatar
Default RE: ls vtec
You can vary compression anywhere from 10:1-13:1 using USDM pistons purchased from any Honda/Acura parts dealer, or from Topline (but I'm not sure of the quality on these). Also, I could be wrong, but I wouldn't doubt it if any OEM piston would hold up as well asType-Rs. Type-R = hype.
http://zealautowerks.com/
Old Mar 25, 2007 | 12:06 PM
riceburner700's Avatar
Default RE: ls vtec
anything over 11.1 i would start running higher octane gas than 91
