This might sound silly
Just a qwik question, what is that c/a/i looking filter that is used for oil applications? They are normally 2 inches in diameter and look just like an aftermarket air filter. What are the benifets of these things and what is their purpose?
RE: This might sound silly
they are to replace the hose that goes from the valvecover to the intake tube. but ive heard a couple of horror stories of the hydrogen building up instead of being sucked out by the vacuum in the intake and causing flash fires in the engine bay.
Hydrogen???
from the oil sloshing around and heating up.
oh I see...do you know exactly how much hydrogen is produced?
not all that much, but enough to cause a problem under certain conditions. i dont think its a widespread problem, but why risk it just to have that hose gone and have some goofy little filters?
Ehhh...I was actually thinking about using that hydrogen:( Bummer.
Its an Engine oil Breather, ive had them before and the Claimed increase in power isnt True but they stop oil going into the inlet manifold and cloging up the valves etc, a little bit of oil may somtimes, after extreme racing, come through the filter but it has a sort of metal foily thingy to stop it leaking too much. My 220GTi Turbo had this and it ran alot smoother.:)
As for hydrogenm building up...never herd that before.:eek: |
its part of your emmisions system. its usually the first thing that i rip off an engine. what it dose is allow all of the oil in the blow by o recirc into your intake to reduce pollution in the env. I cant stand enviormentalists. any ways yea just rip that line out of your intake and strap a breather on and enjoy the extra 1hp
no, its not just emmisions, if it were, just plug the hole. see what happens. its to pull the hydrogen out of the valvetrain area.
