milage turbo question
Old Sep 11, 2007 | 03:23 PM
davidb123's Avatar
Default milage turbo question
is it ok to boost your engine if you have 145 thousdand miles??
Old Sep 11, 2007 | 04:34 PM
BX_Civic's Avatar
Default RE: milage turbo question
If your compresion is good then you shold be ok but the older the motor the better the chance of having a bad seal or something.
If your going to go low boost and set it up correctly you should be ok. Im sure alot of ppl boost without doing a full engine build and there motors last.
The main thing is dont go and run 18psi of boost and expect things to last to long especially if its not tuned correctly.
There are people here who are boosted who will probably chime in with more detailed info.
Old Sep 12, 2007 | 06:59 PM
davidb123's Avatar
ok cool thanks for the info it really helped
Old Sep 13, 2007 | 08:25 AM
davidb123's Avatar
whats a good compression number so tis safe to turbo a car?..well for my engine a d16y7
apoplectic1
Apr 9, 2010 08:09 PM
addiction2bass
16
Dec 7, 2008 08:43 AM
addiction2bass
Aug 22, 2008 06:42 PM
civic94
Feb 17, 2005 08:32 AM
hank
Nov 3, 2004 07:52 PM
