mini me
you dont have to chip it.
Y8 head around $125 to $150
ECU around $80
Intake manifold around $100
Converting your harness around $10 if you do it yourself.
Around a total of $350 to $400 depending on the deals you run across, also remember to get a 99/00 Y8 ecu because if you get a 96-98 one you will need a obd2b to obd2a conversion harness.
ECU around $80
around 25 but the cool thing is if you decide to add a aftermarket cam, valve terrain, and maybe a lighter flywheel(12ish lbs). Throw in a 50 to 75 shot wet kit and you are making good hp for a civic for around $1000
i am tryin to do the same thing!!! i have a 1.6L SOHC NON v-tec and i wanna convert it to a SOHC v-tec.. ok i have a stock D16Y7.. i want to kno wha else i need... so far i have:
- Honda 1.6 Vtec Cylinder Head from a 97 civic ex
- p28 ECU from a 1995 Honda Civic Ex 5 speed 1.6 vtec (d16z6)
- 93 civic ex intake manifod
wha else do i need?
wha else do i need?
khanselman
Aug 25, 2006 12:40 PM
