HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   mini me swap (https://www.hondacivicforum.com/forum/engine-internal-11/mini-me-swap-67883/)
dustinwithanx 07-17-2008 03:19 AM
mini me swap
i hear a d16y7 block and a d16y8 head is alot better than just a full d16y8 block.
tell me if so because i've never studied up on it to much.
if it's not that much better, than i'm not even going to bother and save myself the hassle.
newcivicguy 07-17-2008 11:46 AM
RE: mini me swap
first, can someone explain to me what the mini-me swap is? I have an idea, but someone clarify
trustdestruction 07-17-2008 12:59 PM
RE: mini me swap
ORIGINAL: newcivicguy
https://www.hondacivicforum.com/m_45390/tm.htm
trustdestruction 07-17-2008 01:02 PM
RE: mini me swap
ORIGINAL: dustinwithanx
it's about the same. you get higher compression with the mini-me (y8 head on a y7 block) than just a plain y8, but HP is about the same because of the lower amount of displacement in the mini-me compromises the higher compression.
if you already have a y8 then doing a mini-me is pointless.
newcivicguy 07-17-2008 07:17 PM
RE: mini me swap
about how much did it run in cost as far as the head and ECU?
newcivicguy 07-17-2008 07:18 PM
RE: mini me swap
nevermind....found it.....
itsmycivicduty 07-20-2008 08:51 PM
RE: mini me swap
try google guys. Instant results instead of wasting space on a forum.
