Misfire help
Old Sep 14, 2006 | 06:56 AM
pendleton's Avatar
Default Misfire help
Last night I had to drive through a pretty deep puddle (up to the doors). The car had to work to push through it and the engine bucked a couple times pretty hard. I think the clutch was slipping or something. By the time I got through the puddle, the engine had thrown a code and was running pretty rough. I figured I had soaked my air filter and I might be choking the enging, so I swung into the local parts shop and bought a new one just to be safe. That didn't fix the problem though. As I drove around more, the engine began to run better and would get brief bursts of it's normal self, but would then stumble again under load. This morning I drove about 25 minutes on the highway with no problem, but once I got off onto the surface streets it missed a couple more times. It's not a constant problem, but seems to show up when the engine is having to work. I'm wondering if I have a vacuum problem. Are there any lines on the bottom of the engine that may have been affected by driving through the water? Any other ideas? I thought maybe my dizzy had gotten wet, but I think that would be more of a constant problem. I'm at a loss, any clues? Thanks
Old Sep 14, 2006 | 11:56 PM
cyberx32's Avatar
Default RE: Misfire help
do you have the stock air filter, or do you have an aftermarket cold air intake?
Old Sep 15, 2006 | 09:21 AM
HARI.'s Avatar
did you check the code? you should do that first to tell you exactly what the problem is
Old Sep 15, 2006 | 03:23 PM
Nail I3unny's Avatar
check your wires, plugs, and other electronic crap that can get screwwed up by water.
Old Sep 17, 2006 | 04:40 PM
t34me's Avatar
pull the wires, see if you have water around the plugs
V8DIET
16
Feb 19, 2009 03:22 AM
JakeyMan07
Oct 3, 2008 08:41 AM
dimension4
Jan 26, 2007 06:40 PM
dimension4
Jan 26, 2007 05:04 PM
redcivic99
Aug 29, 2005 09:50 PM
