Motor mounts
I broke my A/C bracket torque mount while removing my transmission. Considering that the A/C is removed from the car, would removing the bracket and torque mount be a good idea? Also, i am considering buying stiff motor mounts, but haven't found much valuable info on d-series mount kits. Anybody have an opinion on hasport vs. innovative vs. inserts vs. $125 ebay poly mounts? I am not going to cheap out, but I don't want to pay $300 for mounts if the payoff is miniscule in comparisson to cheaper options. If I buy the stiff mounts, do i even need the lower torque mounts? From what I hear 3 solid mounts replace the 5 existing bastards.
________ Glass pipes |
Yeah if you have hasport motor mounts you can just run the triangle motor mount supports and you can take out the front torque mounts. I know hasport are great I would vouch for them I dont know about the other companies but hasport mounts are very expensive so if you can find a better deal somwhere else with decent mounts do that. Also you can buy replacement a/c brackets for some engines on hasport.
Thanks man. Anybody familiar with these mounts?
http://cgi.ebay.com/ebaymotors/96-00...spagenameZWDVW Very tempted to buy them, look like a knockoff of hasport and better than stock. ________ Live sex webshows |
