Motor Swap help
Swapped D15b Jdm motor in my 95 ex cause i blew the d16z6 up, installed finally but all motor does is crank, i replace plugs wires cap and rotor and battery and still just cranks at same rate, any help please !!!!!
The first word that jumps into my head is Dizzy.
On JDM ZC engines, there's the same problem. Two of the wires on one of the distributor plugs are switched, so you have to switch them back in order for it to work right (I'm not sure which ones they are.) I'll try to look them up, but sacicons or someone might already know.
And you might want to try and return some of that stuff if you don't need it...
My brother and me worked with it more today and we know its getting fuel and spark our question is the firing order anyone know what that might be, im really fed up at this point and there maybe a civic forsale in the near future if i cant get it to work...
the longest wire goes to the farthest plug and the shortest to the closest.... should be pretty simple from there.. i screwed my order up once but i still got it to run and i could go down the street... with load bangs following me... lol
topdogmancivic92
Aug 28, 2006 09:12 PM
dalifts
ED-EF Swaps
Apr 16, 2005 01:11 PM
hypnotixcrx
Mar 1, 2005 10:10 AM
nwhite82
Dec 2, 2004 01:49 AM
