Is my Civic dying/tired?
My 1998 Civic DX idles around 200-300RPM when sitting still. This seems a bit low, but is it normal? It runs nice and smooth and gets up to 40MPG. Its has an automatic transmission and a little over 169,400 miles on it.
im new here, but have you tried the seafoam? i think it helps with the idle and all, especially with 170k miles on it. maybe timing belt or somthing as well. idk, but thats what i would do. my 92 eg sits at about 500rpm but when its cold like 900rpm.
Originally Posted by kevster92eg
(Post 703723)
Your car most likely just needs a tune-up. Replace the plugs and wires. Inspect the cap and rotor for wear and carbon tracks - replace if you find these. Check the ignition timing with a timing gun. Also, clean the IAC valve. If all of those don't bring the idle up, there's an idle air screw on the throttle body you can turn up a little tiny bit. This should be your last resort as you normally shouldn't need to mess with this. |
Originally Posted by norbster86
(Post 703864)
You don't need to change the timing belt unless it's never been changed or has been 7 years or 60K miles since the last one.
Well, it almost stalled on me today. I haven't had the time to have it checked out. I was coming to a stop at a red light and I noticed the car was shaking quite a bit as I was slowing down. Then once I came to a complete stop, the car continued shaking and it was making a really slow "vroom, vroom, vroom" sound. I kept one foot on the brake and the other on the gas to keep it going because the idle was barely at 100RPM. I drove it to work and then back again and it was fine the rest of the day.
