Need Help
Old Apr 11, 2007 | 08:33 PM
TurboD's Avatar
Default Need Help
Hi guys, I have a question here,. I just got back from a 8 hour drive and theres a strange sound coming from the engine. It sounds like a fast poping sound as if the header is open? But it only happens at high rpm and only when im in gear. I can rev it like mad when its out of gear and I dont hear it...and thoughts.
Old Apr 12, 2007 | 07:02 AM
Default RE: Need Help
Have you made any significant changes recently? Judging by your screen name I'm assuming that you have a boosted d series? Do you have any sort of knock detection? What engine management are you running and when was the last time you had your maps checked out?
I had "popping" on my boosted D too. I did nothing about it, and end up blowing the motor. Get yours checked, ASAP
Old Apr 12, 2007 | 09:09 PM
TurboD's Avatar
No its a stock (sept for I/H/E) d15b7. I have no idea what this could be....it only make the sound under load at high rpm. Im going out to run a compression test right now.....
Old Apr 12, 2007 | 10:58 PM
TurboD's Avatar
ran the comp test and the old girl is pumping out 175 psi +/- 3 psi. so thats fine...anyone have thoughts on this????
Old Apr 13, 2007 | 07:15 AM
Look around man. Search for holes in the exhaust, or anything out of the ordinary for that matter.
Old Apr 17, 2007 | 04:18 PM
TurboD's Avatar
Well I think/hope I've found the problem...I can see a carbon trail leading out of where the header bolts to the DP. Here are some pics. I guess I just need a new gasket and to bolt it in there tighter this time. Strange that it only make the sound under load though.
[IMG]local://upfiles/20097/99E835FF1436422DB952A385E64BFC73.jpg[/IMG]
[IMG]local://upfiles/20097/593EF20BEDAD4210AF590740485CB536.jpg[/IMG]
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
