need help..Civic tune up list
Hey guys...first post here...i have a 2000 Civic DX....what does the tune-up list consist of for my car if i want to do it myself?
RE: need help..Civic tune up list
if you want to do a major tune-up:
Spark plugs: gap and replace also check the wires for cracks Oil and filter: drain and replace Air filter: check and replace if necessary Coolant: check and replace if necessary Valve adjustment PCV valve: check and replace if necessary Timing belt: check for wear and change if necessary Water pump: check for leaks Accessory belts: looks for cracks and replace if necessary Transmission fluid: check flevel and color (replace if necessary) Power steering fluid: check and top off Brake fluid: check level and color (replace if necessary) Front & Rear brakes: replace if most of the thickness has been worn away also check the lines Parking brake: check and adjust Tire rotation: Check pressure and tread and rotate Hoses: check for spongy hoses or cracking (replace if necessary) Fuel lines & filter: Check and replace if necessary suspension & steering: Check for loose components, check cv joint boots for leaks I'm sure i'm missing something, but that should do it.... oh....also check and adjust the timing.... |
