need help with timing belt
Old Sep 3, 2007 | 06:53 AM
Hot94vtec's Avatar
Default need help with timing belt
hey my friend has a d15b8 block with a 93 pm3 head. we are not sure what motor the head is from, but the timing belt that came with the motor is to small, i know that the block came from a usdm 93-95 del sol but i was wondering what timing belt we should get for the motor? Thank you
Old Sep 3, 2007 | 11:07 AM
Default RE: need help with timing belt
have ya loosed the tensoner?
Old Sep 3, 2007 | 03:22 PM
jwsimons's Avatar
thats really scary, not knowing what head your using, post up a pic, somebody will probably know which it is, in order to get the belt with the correct number of teeth, you need to know which head it is, or you will not be able to time the cams to the crank..... PING, PING, PING.. thats your valve stems punching holes in the pistons
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
brokenbones
Mar 25, 2007 09:43 PM
hoppyumr
Nov 23, 2005 02:28 PM
