NEED TO KNOW!!!
Old May 22, 2006 | 07:53 PM
F23AccordLX's Avatar
Default NEED TO KNOW!!!
I am starting my swap in my 97' Civic. I am putting in a D16Z6 and i need to know if i can use my oil pan of my D16Y8 so i can still use the brackets that go from the tranny to the oil pan or will i have to use the D16Z6 oil pan and go to honda and buy the brackets? I am using the tranny that is currently in the car, the original one.
Old May 22, 2006 | 09:36 PM
Nail I3unny's Avatar
Default RE: NEED TO KNOW!!!
why swap an OBDI into an OBDII?
Old May 23, 2006 | 08:16 PM
Dude, i just need to know if the oil pans will switch
Old May 23, 2006 | 10:29 PM
sillyredcivic's Avatar
I think they should. I believe that the same size motors have interchangeable parts
Old May 25, 2006 | 03:33 PM
bump, i need a definate awnser
Old May 30, 2006 | 12:37 AM
finalimpact's Avatar
nope(sorta)........pan sumps are different heights between the 2 engines. also 2 studs on the z6 oil pumps are in different locations in comparison to the y8. you can remove the studs and bolt the pan up, but your oil level readings would be wrong.
StifflersMom
Feb 27, 2011 10:17 PM
SamTay
Jan 4, 2008 03:31 PM
Luke_Jones
Dec 2, 2007 03:33 PM
windcalmer
Nov 18, 2006 09:00 AM
Colby Day
13
Oct 1, 2006 10:10 PM
