New cam
Whew, just got my new cam installed (59300)and man is that thing loud. Sounds like the valves are gonna rattle out of there. The lash is in spec so I guess it just sounds like that. The idle is smooth though.
Butt dyno says it's making power right from off idle. Really smooth acceleration. Installed my new turbo today too. It's a rebuilt, ported and polished 14b. Same turbo that I was running but with the little extras. It spools a little faster and hopefully won't be leaking oil like my other one. It had 170k on it so it was overdue for a rebuild. Anyway, probably make it to ther track this friday so we'll see what's up. |
RE: New cam
wow, new cam and new turbo, sounds like a good upgrade. how aggressive is the cam since your idle is really smooth as well as engagement?
RE: New cam
It's as aggresive as you want to get with FI. It'sa Street/Strip cam. Not for the fainthearted because unless you know what you are hearing,people will think something is wrong with your car.
It's this one. SEVERE STREET / COMPETITION Best performance cam available. Large increases above stock cam from off idle to the rev limiter. Excellent high RPM power. Requires Spring #912-16. 2000 to 7200 59300 http://www.zex.com/Base/Images/Butto...BuyNow_001.gif VTEC PRI SEC 260 232 236 268 220 190 194 216 .455" .300" .310" .430" 107° 111° 115° 111 |
RE: New cam
Well, that didnt work like I wanted. Those are the lifts and durations if you know what you are looking at.
RE: New cam
yeah, i see, looks like a pretty good increase over stock, lol
RE: New cam
Video or ban!
RE: New cam
ORIGINAL: mxs Video or ban! |
RE: New cam
ORIGINAL: mxs Video or ban! At least some pictures. You usually take pictures when installing something new. |
RE: New cam
ORIGINAL: Street Sniper It's as aggresive as you want to get with FI. It'sa Street/Strip cam. Not for the fainthearted because unless you know what you are hearing,people will think something is wrong with your car. It's this one. SEVERE STREET / COMPETITION Best performance cam available. Large increases above stock cam from off idle to the rev limiter. Excellent high RPM power. Requires Spring #912-16. 2000 to 7200 59300 http://www.zex.com/Base/Images/Butto...BuyNow_001.gif VTEC PRI SEC 260 232 236 268 220 190 194 216 .455" .300" .310" .430" 107° 111° 115° 111 (edit) not what you said, I get that. Just the part about the cam specs...or whatever they are |
RE: New cam
where did you buy your cam from?
Ive been thinking about getting a new one, but I might swap for a B |
