new cams
If i get a new cam for my sohc vtec, what will it do for my perfomance? What exactly do cams and camshafts do?
RE: new cams
Im not sure what the difference between cams and camshaft but i like to call them camshaft. Anyways i heard that its kinda hard to install camfshaft since you gotta kinda take your engine apart.
RE: new cams
Jus to clarify, the cams are on the camshaft(s). They are the lobes that activate the valves. It's actually not very hard to replace camshafts. You just have to be very very careful. With SOHC engines, you have to take the entire valvetrain off and keep it clean and assembled. After that, you just have to remove the cam gear(s) and the camshaft retainers (on the ends) and it should come right out. You probably want to find some directions if you want to do it yourself.
RE: new cams
will aftermarket cams help with performance? Also should i replace just my cam or the comshaft too?
RE: new cams
its all one piece. and yeah, it will help noticeably. but you should probably do other mods first. like the standard intake/header/exhaust.
RE: new cams
ORIGINAL: ballplaya4eva07 will aftermarket cams help with performance? Also should i replace just my cam or the comshaft too? |
RE: new cams
On a SOHC VTEC (like ballplaya4eva07's) I believe there are 20 lobes on the camshaft.
RE: new cams
also you should probably (depending on the new cam you get) think about replacing your valve springs
RE: new cams
How many new cam gears will i need to replace them all? And only 1 camshaft right?
RE: new cams
SOHC = single cam gear.
And yes, only one camshaft |
