New spark plug wires
Old Aug 30, 2006 | 11:11 PM
Proto05's Avatar
Default New spark plug wires
I want to get this It helps with the looks but does it also deliver any HP or fuel effciency as promised? Will it work with the spark plugs I have in there now? And to install it is simply pull out old wires, put in new ones rite? thanks
Old Aug 31, 2006 | 02:28 AM
E2EK1EL's Avatar
Default RE: New spark plug wires
What size are your stock wires? 8.5mm? Those are 10.2's, I've heard people say anything over stock size in a stock engine will steal power...
Old Aug 31, 2006 | 08:09 AM
I would never use anything other than OEM or direct OEM replacements unless I was driving a HEAVILY modded car.
No, bolt ons do not mean heavily modded
Old Sep 6, 2006 | 09:39 AM
sway2003's Avatar
Even if you were to replace them with thicker wires, they wont do anything because the rest of your ignition system is stock. When you do an ignition system you want to do wires, distributor, the works. It would be completely useless and a waste of money if you did all the upgrades to the ignition since its not HEAVILY modded like forty said. HEAVILY modded is pretty much everything you can do, IE turbo, internals, valvetrain, fuel system, etc. It will infact make you loose power and money since the wires are oversized they are straining the rest of your ignition system and more then likely cost you a distributor. I work in a garage, and a customers civic was running like crap, popped the hood, saw the oversized wires and it cost him a distributor with a new set of OE wires. Trust us, OE is ideal unless HEAVILY modded.
skytanker2003
Jul 19, 2005 08:12 AM
smokingemcee
May 17, 2005 08:15 PM
fast93civic
Feb 5, 2005 04:47 PM
bulletman0_0
Nov 8, 2004 11:17 PM
civic1.5uk
Jul 24, 2004 03:15 PM
