No Oil in filter!
Old Jun 2, 2007 | 11:03 AM
bdrmachine's Avatar
Default No Oil in filter!
I swapped a 1998 D16Y5 into my 1995 civic VX. The engine came from a car I had that was totaled-out (rear ended). The engine had less than 40000 miles on it and ran fine before the crash. It sat in my shed for 6 years or so. Before I swapped it out I pulled the head to inspect it. All looked fine. I had a valve job done while it was off. The timing belt and water pump was also changed. I got it running last weekend. It sounded fine. I let it run for 30 to 45 minutes. Other than the ruff idle, do to the IACV being for an automatic instead of a manual there was a very slight oil leak. The leak appeared to be from the corner of the head in the front of the car on the tranny end. Today I pulled the intake to convert it to a manual IACV. I had to remove the oil filter to get at a nut. This is where the question starts. The filter had NO OIL in it. What could be wrong? Would the engine run 30 minute without oil? Thanks Bert
cvcrcr99
Nov 16, 2011 01:55 PM
WILMER007
Oct 14, 2009 07:42 PM
Seafoamgreencivic
34
Aug 12, 2008 09:30 AM
oilltd
Jun 10, 2008 04:06 PM
