IS THIS NORMAL??!?!?!?
WOW. Recently i broke my timing belt so i had to remove the whole headwork tu chek if any valve broke. thank god none broke. but i make and very weird thing my car is running in low compression pistons is this normal? i though it had flat pistons. i have a 95 coupe ex engine D16z6
RE: IS THIS NORMAL??!?!?!?
whats iy reading st cuz most honda and acura motors reads at 110 or over on a average if its below then u might have a problem cuz it has happen 2 me a low compression not from timing belt but from a head gasket
I can not read either of your posts
me ? well my bad heres what i meant 2 say
whats is the compression reading it cuz most honda and acura motors reads at 110compression or higher on a average if its below then u might have a problem cuz it has happen 2 me a low compression not from timing belt but from a blown head gasket |
but what i mean is that my engine d16z6 has low comppresion pistons, and i was wandering if those are the stock piston of that engine or the past owner ofmy car change the original to those to make it turbo???
