IS THIS NORMAL??!?!?!?
Old Mar 12, 2007 | 06:52 PM
HaZe89's Avatar
Default IS THIS NORMAL??!?!?!?
WOW. Recently i broke my timing belt so i had to remove the whole headwork tu chek if any valve broke. thank god none broke. but i make and very weird thing my car is running in low compression pistons is this normal? i though it had flat pistons. i have a 95 coupe ex engine D16z6
Old Mar 12, 2007 | 06:55 PM
skylinecivic's Avatar
Banned
Default RE: IS THIS NORMAL??!?!?!?
whats iy reading st cuz most honda and acura motors reads at 110 or over on a average if its below then u might have a problem cuz it has happen 2 me a low compression not from timing belt but from a head gasket
Old Mar 12, 2007 | 07:02 PM
Tater's Avatar
I can not read either of your posts
Old Mar 12, 2007 | 07:07 PM
Banned
me ? well my bad heres what i meant 2 say
whats is the compression reading it cuz most honda and acura motors reads at 110compression or higher on a average if its below then u might have a problem cuz it has happen 2 me a low compression not from timing belt but from a blown head gasket
Old Mar 12, 2007 | 09:34 PM
HaZe89's Avatar
but what i mean is that my engine d16z6 has low comppresion pistons, and i was wandering if those are the stock piston of that engine or the past owner ofmy car change the original to those to make it turbo???
mill$civic
Nov 18, 2006 05:56 PM
Mark
Jan 3, 2006 11:42 PM
civiccx97
May 28, 2005 05:55 PM
gunner11
Jan 23, 2005 07:28 PM
kellog
Dec 5, 2004 01:56 PM
