oil leak between trans and engine
Old Oct 2, 2006 | 12:35 PM
rit14623's Avatar
Default oil leak between trans and engine
I changed the oil in my Civic yesterday. I saw fresh oil leaking where the transmission and engine meet. It wasn't there when I last changed the oil in my car so I know it's new. Plus, the amount of oil that got drained wasn't a lot.
Anyone know what seals are worn and how difficult it is to replace the seal or seals.
Old Oct 2, 2006 | 04:22 PM
importcivicus's Avatar
Default RE: oil leak between trans and engine
First off what year and model of car do you have? And how high on the engine is it? It may be a rear main seal. But I dont want to miss guide you at all. It also maybe coming from inside of the tranny. Thats the only way you can find the leak.
Old Oct 2, 2006 | 07:34 PM
t34me's Avatar
sounds Exactly like rear main=have fun trying to do that on your own, just pay up and avoid the headache
Old Oct 2, 2006 | 08:01 PM
mxs's Avatar
mxs
yeah I'd say rear main seal too... it's behind the flywheel, so you'd have to drop the tranny, etc.
I saw it done on a Neon once, pretty straightforward, but the engine was out of the car at that point
Old Oct 2, 2006 | 08:09 PM
b8teen's Avatar
i have a suggestion....make sure that u didnt just spill fresh oil onto that spot. u say that its fresh, and it wasnt there before. so wipe it clean and check it agian after a day or two.
Old Oct 2, 2006 | 08:39 PM
HARI.'s Avatar
ORIGINAL: mikezcdx
take this advice before you start taking your engine / tranny apart. main seal usually last quite a while
Old Oct 3, 2006 | 03:09 PM
rit14623's Avatar
Well, I've had this problem (real main seal worn out) with a couple of other cars, but I've always brought it to a garage to get it done.
It's a 95 Civic DX, 1.5 engine, 185+K miles
Anyway, the oil isn't leaking heavy now. I noticed it on the transmission housing, not the ground.
Old Oct 12, 2006 | 12:02 AM
Dogmeat's Avatar
Is your clutch slipping at higher RPM?
I ask because I just rolled 176K and got a small leak...I slip at 4000RPM, but normal granny driving is ok.
knuckleduster271
Dec 4, 2011 02:04 PM
theRDRman
Nov 28, 2011 04:18 PM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
