oil plug spinnin
rrrrrrrrrrrrr simple oil change gon wrong smh lol
so im tryna take off the drain plug for the pan and its jus spinnin. im using da ratchet and it turns it but its not coming off. so i try to close it and again it jus keeps turning. i cant leave it like dat cuz oil is drippin. any idea how to get this thing out??? |
its stripped. now forget about your car and take an english class.
Originally Posted by jprommel
(Post 663072)
y0 dawg u needz a knew oil pann
^what he said. The oil pan bolt is stripped out. Put a pan under it and let it drain. Have a friend take you to your local junk yard and snag a used one. Or buy new from Honda, not that expensive. Not even a big deal to swap out. You just have to get up under the car and undo all of the bolts holding it on, save the gasket or replace it to be thorough.
