performance camshaft
anybody know if there's a aftermarket Cam for the D15??
i'm wondering if using a better/bigger cam would yield the same or maybe better performance gains on a D15b7 than doing a Mini-Me swap from a D16Z6. anybody have any ideas? |
i'm not sure if there is one available or not. you might be able to use D16Z6 Toda VTEC Killer cams on the D15B7 but idk if you can.
You definitely won't gain as much as you would from a mini-me swap though. |
plus most cams you would really need to be tuned to get the most gain from since most cams are aggressive and you would need to adjust your fuel maps for the cam
throw the d16a6 cam in there
Originally Posted by riceburner700
(Post 625747)
yeah the d16a6 and the d15b7 have the exact same mold casting just the a6 has a little more aggressive cam in it. if you want a regrind or custom go with exospeed.com
will it make any noticeable sort of difference?
yeah people say it makes a difference
hmmm, i'll c if i can find one @ parts galore when i go out there l8r
+1 on the a6 cam it would be an upgrade for the d15b7
