pinging in the engine
hey guys,
ive got a 94 ex, for the past little while ive had this pinging noise in the engine (especially at low RPM's or while going uphill) and it feels like it has less power than usual. I've tried higher octane gas and it didnt help much...have any of you had this problem? or does anyone have any suggestions as to what i hould to?? |
RE: pinging in the engine
Get the valves adjusted and the timing set. You'll notice a difference.
ORIGINAL: Kappa22 Get the valves adjusted and the timing set. You'll notice a difference. what octane fuel are you running? and has the cylinder head ever been shaved? |
is adjusting the valves a job i should leave to a garage or is it something i can do myself?...im running on 87octane, Ive used 94 and the pinging and knocking was reduced but still lingering in the backround...the cylinder head has never been shaved, what would that do?
Thanks for your help guys. |
ORIGINAL: addy79 is adjusting the valves a job i should leave to a garage or is it something i can do myself?...im running on 87octane, Ive used 94 and the pinging and knocking was reduced but still lingering in the backround...the cylinder head has never been shaved, what would that do? Thanks for your help guys. |
