Piston Rings....
What are some good piston rings that i can get for cheap and where can i get them... For d15b... compression is like70 on all cylinders... ouch!
RE: Piston Rings....
you might have to also bore the cylinders .020 and get slightly bigger pistons/rings if the compression is that low
i was told that Hastings makes really good rings. i'm getting a set for my B. check em out at http://www.hastingsmfg.com/
