please read! engine swap
Ok here's the deal Ive purchased a re-built Integra LS dual over head cam motor and droping it into my year 93 coupe Honda civic. The old motor is the same stock motor that came with it off the asembly line. Is there anything I need to know as far as tool's....anything at all any advice would be apreciative
RE: please read! engine swap
you mean tools to install your new motor? buddy, if you dont know whats required during install...i dont think you should be doing this without someone who does
well this is a tough 1.... honestly u need a lot more than a motor, u need a matching b series tranny, motor mounts, bracket,ecu, axles, shift linkage, started, alt., power steering pump ifu want, exhaust manifold.... i can go on and on so if u want to just p.m. me and tell me everything u have so far and ill inform u of everything else u need and want and where u can find it, then ill help u out with installation, where u from???? keep me in the no....via myspacesearch mrkevindshore@yahoo.com
