plug wire questions. (help!)
well, as some of you may know, or not, i just swapped a fully built y8 block and z6 head into my 99 ex.. slapped on a garrett t3/t04e bb turbo, and about a million other things, shooting for 300+whp on a mustang dyno, but i cant get 'err to go so heres my problem.
car fires up, 2 seconds later it putters out, its getting gas, the cylinders are lubed, grounds are all in order, check engine lights are all ok'd (just an o2 sensor), and thats it! i think the plug wires are shot, when i put the screw driver by them to check for spark all they put out is a kind of sad yellow bolt, i thought they were supposed to be blue? any advice? if im going to change the wires i guess ill also replace the distributor rotor, but i kinda want to know if thats how the wires are supposed to be acting? cuz wires aint cheap [&:] thanks guys! -didder edit::: i am running my 99 civic ex distributor cap and rotor on my 92-95 distributor, could that be whats causing my problems?! |
RE: plug wire questions. (help!)
Weak spark likely indicates a bad coil or ICM in the distributor. The manual (see signature below) describes how to test the coil with a multimeter. The ICM input tests should also be helpful.
Edit: I am not sure about the cap and rotor compatibility. |
whats the icm?
1 Attachment(s)
Car tuned or no?
May very well be your basemap. |
not the basemap, my chrome basemap didnt work and it worked on my y8 stock motor with same injectors.. cars running rich too, blows black smoke from the e-cutout when it fires over for 2 seconds.
new one is from phearable.net, its a hondata s300 |
