port & polish
does anyone know how much a port & polish runs $ wise?
RE: port & polish
Anywhere from $500-$800 depending on the shop but make sure you bring it to a reputable shop though. If the shop doesn't do it right, it could be a major headache.
RE: port & polish
thats something you definately dont want to cut corners on... do it right.
RE: port & polish
Thanks for the info... I am looking into getting this done is it something i should do is it worth that 5 to 8 hundred$ ?
RE: port & polish
you will definately feel the difference... its just like getting a bigger motor...
RE: port & polish
port and polishing the head makes the biggest difference when aftermarket cams, high comp pistons come into play as well as forced induction. IMO well worth the money in the long run.
RE: port & polish
thanks man actually im lookin into swapin in a D16Y8 because my engine had 200k + on it and ive talked to a few ppl and they tell me to go witht hte swap
RE: port & polish
go with the swap, that kind of money into the head, then the bottom end will go out.
RE: port & polish
yea thats what ppl have been telling me... im gunna do the swap when i have the time and the money i have heard that the d16y8 isnt a hard engine to find which means it isnt a very expensive swap which is exactly what i need... due to the low budget! well thanks for the info
RE: port & polish
what year car is this in? are you running the stock motor right now? if not, what motor is it.
