Is this possible?
Old May 24, 2007 | 05:52 AM
Default RE: Is this possible?
ORIGINAL: Marty
How about if you cant answer the guy dont post, he did not ask what to swap in or anything about boost or spray. Ok man first off you need to get a Y8 head and do a mini me, use the Y8 head, 99/00 Y8 automatic intake manifold, and a 96-98 ex manual ecu. Before putting the head on I suggest you have it shaved and a valve job done on it along with any porting and polishing you want done. I would use the www.akmee.com type r sohc valve terrain kit, it is not list for sale yet but you can email them and they will sale it to ya. You may want to upgrade your transmission to a 92-00 ex unit as it has shorter gears anyway. Go ahead and use a stg 1 replacement clutch or maybe a stg 2 excedy. Run a light weight flywheel but not to light, a stock flywheel shaved to around 13lbs would be ideal. Run a good header like a bisimoto or hpracing 4-1 design. If you are willing to do the work you could fab up some ITB's also out of cbr 600f3 throttle bodies. With out the throttle bodies and with a good intake and exhaust setup you could see mid 140's on the whp and run deep into the 14's in the 1/4 mile with that if you shave a little weight.
Apparently you can't answer him correctly either, as all that is going to cost way more than a swap
Old May 24, 2007 | 08:37 AM
Marty's Avatar
So what is the most naturally aspirated horsepower i could make within reason, and without spending more than a swap would cost?
Your talking $1200 to $1600 for all that I listed, by the time you swap even a B16 your looking at over $2000 easy. People forget when you buy a engine that has 30k+ miles on it that it needs to be gone through(timing belt, water pump, belt tensioner, gaskets, so on and so forth)
Old May 24, 2007 | 09:04 AM
MY99SI's Avatar
ORIGINAL: Marty
not to get off topic or anything but someone should do a write up on how to do that if it hasent been done already
Old May 24, 2007 | 09:56 AM
riceburner700's Avatar
honda tuning actualy did a sohc with oem parts that made more power than a b16.
Old May 25, 2007 | 07:16 AM
96civichb's Avatar
ORIGINAL: MY99SI
^+1 That would be awesome.
clutchjunkie
May 29, 2005 01:21 AM
lazyjoe
Apr 18, 2005 07:46 PM
warrior86
Jan 12, 2005 08:29 PM
Not_Yet_Decided
May 27, 2004 04:14 PM
green98lxsedan
May 25, 2004 09:51 PM
