Prepping a B16A2
Old Nov 11, 2005 | 01:19 PM
Nail I3unny's Avatar
Default RE: Prepping a B16A2
actually 8 might be pushing it if its driven daily like that. it will wear down exponentially faster. you prolly wanna stick with 6, maybe 7, on a daily driver. get a boost controller for those times when you need the extra PSI or 2
Old Nov 11, 2005 | 08:45 PM
sacicons's Avatar
ORIGINAL: Dickie
i dont want to say ne thing against sacicons cuz hes the man, but my friend had type r cams in his civ before he put his turbo in, but when he actually did, he took em out and put the stock ones back in.. or otherones i forget. but why would u pick the type r cam sacs?
the stock ones are actually better for power than having type r ones. the key is, i would only use the exhaust cam from the R. the extra flow on the exhaust side helps spin up the turbo faster. if you use both cams, the overlap, which is good for NA motors, will hurt the power on the turboed car. it will actually push your fresh charge straight from the intake valve out the exhaust valve, instead of into the cylinder to be burnt. and if you use a type r cam on the exhaust side, adjustable cam gears are a great idea, then you can dial out more of the overlap.
Captain_Sl0w
Oct 4, 2008 03:05 AM
thep0stman69
Jun 19, 2007 08:42 AM
94DX
Jun 8, 2007 07:48 AM
Blackhatch124
EK Swaps
Nov 5, 2004 09:56 AM
Blackhatch124
Sep 26, 2004 10:44 AM
