Python Vemon 400 control module
do these things even work has anyone tried one? I saw it in Summit. And if they do work is it worth the $300 price tag. It's for a 2000 Civic Ex V-tech, or is there a better controller out there
RE: Python Vemon 400 control module
summit racing is a reputable co. chances are what they sell is good quality and will do what it says it will do........its vtec..:D
its basically a chip for your ecu with an on/off function also contolable by the tps signal. you could have a shop burn you a chip designed to work with your car according to your modifications for 1/4 that cost.
i put the vemon module on to a neon and it works, but it does not give you 25% more power like they say. it gave it like 7-12% more power. is it worth the $300 no. it has one wire on the tps and one wire on the map sensor. it is conneted to the tps because it only comes one at WOT. the other wire changes the voltage going to the ecu from the map sensor and gives the engine more fuel.
its VTEC not VTECH......they make cordless phones.
lol
anyways, with luck I will be installing venom 400 this weekend, and if I get it one I will post as to what every one wants to know, does it work?!!! |
didn't get a chance this weekend perhaps next.
you need to get ur shiit together bro....i buy something for my car i install it lol......even if its 4 am.....u kno how to make coffee rite>?
lol, tried to install skunk2 mani with a TB with a friend of mine yesterday couldn't do it, ran out of time he had to go to work. We just couldn't get to the two rear bolts that were under the runners. I was hoping that would go on and the venom would be next but nope. Maybe next week.
where u from?
