quick n' easy q
if i have a non-vtec DOHC engine how do you make it vtec, or can you, easily?
a chip, hardware? |
RE: quick n' easy q
Swap the V-Tec head and get a V-tec ecu. Read Mini Me conversion to get an idea. It's the same concept except that you have dual cams.
RE: quick n' easy q
LSVTEC. DOnt rev it too high though.
RE: quick n' easy q
thanks that deff answered a lot of questions, just 1 more though
can you swap the main block say from a sohc to a dohc and then do a mini me swap? just woundering |
RE: quick n' easy q
huh? like, put in an LS, then swap on a VTEC head? if its DOHC, its called frankenstein, its only called mini-me if its SOHC. but a full DOHC swap is a better engine, and a better idea.
