Quick Thermostat question
Old May 4, 2007 | 04:15 PM
Infraeon's Avatar
Default Quick Thermostat question
When I change my thermostat in my 98 DX will I have to drain all the coolant or can i drain just a little?
thanks
Old May 4, 2007 | 08:22 PM
droopy128's Avatar
Default RE: Quick Thermostat question
Don't worry about draining it.. put a pan under the car to catch the spill when you remove the old thermostat, which is a fair amount of coolant will spill..
Old May 4, 2007 | 10:09 PM
dfdon's Avatar
might as well drain it cuse you are going to introduce alot of air to the system then follow the write up for draining coolant in the DIY section
Old May 4, 2007 | 11:41 PM
riceburner700's Avatar
i would just drain it rather than TRYING to catch catch it running off the block
THE_CRIPPLER
Dec 6, 2005 08:26 AM
93SiHb
Oct 25, 2005 07:48 PM
dimaguila1
Mar 2, 2005 11:28 PM
StifflersMom
Feb 1, 2005 06:19 PM
scottk
Jan 10, 2005 09:34 PM
