Rebuild kit?
Hey looking re build the engine on my 95 honda civic ex 1.6l vtec. Not looking to make more hp just looking for a rebuild kit that has all the stuff I need for this task. Any ideas on a good place to get this and what all to look for in a kit is greatly appreciated thanks.
Re-build as in pulling out pistons, or simply replacing gaskets.
Originally Posted by cvcrcr99
(Post 772148)
I was thinking something like this set http://www.nopi.com/dsp_parts.php?vsubpcdesc=Engine Compartment | Engine - Rebuild Kit
BRONZE KIT - D15Z1 - 16V - SOHC Vtec - Contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable) and a set of expansion plugs - Also contains oil pump and water pump Mfg# EKH21VB, NOPI# 102+0988 |
Any feed back is appreciated thanks.
is this chris fish?
